Island Packet 40 - 168,500 $ aux USA
4095 lectures / 1 contribution / 0 nouveau(x)
ORANA 44 (Catamaran)
sujet n°113109
Un ami américain venant d'investir dans un cata vend son cotre de voyage, CIELO,  un Island  Packet 40 en excellent état:
$168,500 - Deltaville, Va
An absolute must-see. If you are serious about cruising, you owe it to yourself to look at Cielo. Owner is an engineer with 35+ years of sailing/cruising experience who bought and equipped her with the intention of owning her forever. This is the best IP40 on the market, and at a bargain price.
The difference between her and others on the market is in the quality of her installations and thoughtful upgrades. She has been outfitted by a cruising couple for a cruising couple. She’s clean, comfortable, energy-independent, and maintained at the highest level. She spent her first 6 years on fresh water.
More Photos: https://picasaweb.google.com/kevinandlizz/CieloIslandPacket40ForSale
A few highlights of Cielo:
Energy Use & Power Generation:
· Complete gut-and-rebuild Custom Fridge & Freezer ($10k+); uses only 40 amps/day in the Caribbean. Everything is at hand and easy to access, freezer keeps ice cream.
· 260 Watts of Solar generates enough power for complete energy independence (and a 4kw Fisher-Panda genset just in case).
Above Deck:
· Wells Marine Arch ($12k). Custom designed and overbuilt. Davits are no substitute for a proper arch. Dinghy is lifted high and clear for visibility at sea. Solar panels, radar, backup antennas, outboard crane all fit securely with room for more.
· Quantum Cruising Sails (3 seasons, excellent condition). Full-batten Main, Genoa, & Staysail
Comfort & Convenience:
· Reverse Cycle A/C and Heat ($10k).
· Ultra-suede Salon Cushions ($10k), Custom Cockpit Cushions.
· Custom Memory Foam Mattress ($3k). You will sleep like a baby.
Equipment List - 1995 Island Packet 40 “Cielo”
Deck & Boat Handling Gear
· Wells Marine Arch w/ integrated Dinghy Davits, Radome, & Solar
· Lewmar V3 Windlass (new 2013, excellent)
· 60lb Manson Supreme primary anchor w/300 ft 5/16” G4 chain
· 45lb Delta secondary anchor w/ 150’ 5/16” chain + 150’ rode
· Edson Stern Rail Outboard Motor Bracket (up to 15HP 4-stroke)
· Shurflo Salt Water Washdown Pump
· Mobri dual radar reflectors
Sails & Rigging
· Tides Marine Strong Track UHMW low friction sail track & batten cars
· Quantum Cruising Sails (3 seasons, excellent like-new condition)
· Full-batten Main, Genoa, & Staysail
· Mack Sails MackPack Mainsail Cover w/ Lazy Jacks
· Forespar Line Control 10’-18’ Telescoping Whisker Pole on Mast-Mounted Track
· QuickVang Model C-16 Rigid Boom Vang
· Garhaur LLC-3 Genoa Cars
· Lewmar coaming-mounted furling winch
Electrical & Mechanical
· 260 watts Kyocera Solar Panels on Wells Arch
· BlueSky SolarBoost 2512i 25 Amp Solar Charge Controller w/MPPT
· Xantrex LinkPro 2-bank Battery Monitor
· Xantrex Freedom 20 2kW Inverter/100 Amp Charger w/Freedom Remote Panel
· EastPenn/Deka 8A31DT AGM Batteries, 420Ah Primary + 105Ah Secondary (1 season)
· Fischer Panda 4000SC 4kW Genset, 709 hours
· Variprop/Prowell 18” 3-blade Feathering Prop
Engine
· 51HP Yanmar 4JH2E, 2947 hours
· Balmar MaxCharge MC-612 100Amp Alternator
· Racor 500MA Fuel/Water Separator & Filter
· Extensive spares (injectors, engine mounts, sensors, belts, new instrument panel, more)
· Full soundproofing in engine compartment
· Stainless Steel Exhaust Elbow
· Excellent condition, pristinely maintained
Galley & Interior
· Cruisair SMX 16,000 BTU Reverse Cycle A/C & Heat
· Glacier Bay MicroHPS Hybrid 12V electric holding plate Refer/Freezer
· Custom 8 cu ft Refer/4 cu ft Freezer Installation with 6in EPS insulation, acrylic shelving, and separate latching lids. Uses only 40amps/day in the tropics.
· Ultrasuede Salon Cushions
· Custom Interior Speakers w/Teak cabinets
· Force 10 Slimline Model 12000 Propane Cabin Heater
· Seagull IV X1-F Drinking Water Purification System
· Custom 8” Memory foam mattress w/ Custom Fitted Sheets
· Jabsco Macerator Pump w/RI approved control switch for overboard discharge
· Heads plumbed with hard PVC and flexible couplings – ZERO head odor!
· TankTender holding tank monitor
· Custom Rugs & full set of Towels & Dishes
· Glebe Creek CS-3 hinged companionway screen doors w/ acrylic inserts
· Custom Book Shelves in Aft Cabin (holds TONS of large books & manuals)
Electronics
· ICOM IC-M802 SSB w/ dual Dynaplates, AT-140 Tuner, & backstay isolators
· Raymarine ST-6000+ Autopilot w/ Type-2 Linear Ram Drive
· Raymarine 2kW Radar
· Raymarine ST-600 Remote
· Raymarine RL-70/RC520 Plus Radar/Chartplotter displays at helm & nav station
· Raymarine ST50 Depth/Wind/Speed
· Standard Horizon Quest+ GX1256S VHF Radio w/dual antennas
· Standard Horizon RAM+ Cockpit Remote Control VHF Mic
· Air802 AP-G300 1,000mW Commercial WIFI access point w/ 18dBi antenna (2nm range)
Cockpit
· Dodger & Bimini w/connector & full cockpit enclosure
· Custom folding cockpit table (seats 4)
· Custom cushions
· Magma Newport Grill w/ stern rail mount & hose connection to primary propane tanks
· Polyplanar cockpit speakers
Maintenance/Other
· Bottom Peeled & Barrier Coated w/ Interlux InterProtect 2000E
· Chainplates carefully maintained & sealed w/ GE Silpruf sealant
· Aluminum tanks carefully maintained – NO chlorine EVER!
· ALL manuals & extensive spares
Dinghy & Outboard
· WestMarine RIB-310 10’ Hypalon RIB (1 season)
· 1998 Evinrude 2HP 2-stroke outboard (approx. 50 hours)
· Custom canvas sun cover (1 season)
Optional Equipment
· 15HP Honda 4-stroke
· 406MHz GPS EPIRB
· Symmetrical Spinnaker
