Mise a jour du fabuleux soft Nasa world wind v 1.31
3844 lectures / 3 contributions / 0 nouveau(x)
sujet n°80499
Salut a tous, J avais lance un post plus bas : Pour ceux qui veulent voir notre planete de pres ou de loin Voici une mise a jour assez interessante, mais pas encore teste : http://www.clubic.com/telecharger-fiche14069-nasa-world-wind.html Les changements : New Features & Fixes - Tile downloading optimizations - New measure tool (press "M" key) - New menu item to redownload imagery for the current view - Added icon layer mouseover text - Fixed bug with downloading tiles outside bounding box - Added minimum and maximum display altitude for TerrainPath layers - LayerSet.xsd schema changes; add-ons for previous versions may need to be updated - Added optional anti-aliasing of placenames (configure in the World Settings window, Alt+W) - Cache: .txt placeholders for tile not found errors now deleted after one day - For certain user interface elements, World Wind now uses the World Wind Dings font instead of Wingdings 2 and Wingdings 3 - Added command line option "/f" for full screen - "Planet Gravity" renamed to "Planet Inertia" - Added distance, tilt, and field of view to extended position information - When Tahoma font isn't available, default system font is now used - Installer: translations added or fixed for several languages; corrupt installer bug fixed - TerrainAccessor now saves terrain cache in \Cache\Earth instead of \Cache - Local settings directory moved from \Documents and Settings\[user]\Application Data\NASA\NASA World Wind\[version] to \Documents and Settings\[user]\Application Data\NASA\World Wind 1.3 - Source code now builds under NAnt - 3 new community-contributed add-ons: Highest Mountains, Population Density, and World Cities. Bon voyage Sourire A +
LAGOON 43
réponse n°77477
A quoi sert ce soft STP, avant de l'installer sur mon ordi, je préfère savoir si cela va me servir.
www.belledelune.com
réponse n°77480
Salut,
C est un soft qui montre la planete en 2 et 3D...
Avec un survol tres correct entre 5000 km et 10000km d altitude...
Plein de renseignements, comme la position en degres, nom des villes, relief, etc...
Le mieux est de jeter un oeil sur le lien, et telecharger apres Clin
Tres impressionnnant pour un soft gratuit !
Attention + de 170 mo a telecharger, mais apres que du bonheur...MDR
A +
